LB7 low RPM "bog"
Luvss350
Aug 25, 2017
9
silverton OR
Hi This is my first post here and i think im in the right spot
My dad has a 04 duramax LB7 we just did head gaskets and 20 over injectors and installed a fast 150 lift pump and now the truck has a bad bog leaving intersections. We cant figur out why it bogs so bad The bog hapens stock tuned(100% factory) or with the edge chip in it or with efi live in it (what little i know about tunning diesels) i corrected the injector polse width and tryed other stuff i read on here i thought would help but nothing did.
The bog is from idle to about 1800-2000 rpm then the truck black smokes and takes off (my dad dose not want black smoke) if you let off the throttle and get in to it agian and rpm are above 2000 no bog it only hapens if the rpm drops below 2000
Other mods the truck has is a air aid air filter and intake and changed the wastgate and a bd disel stage 3 tranny and i think thats everything
Any help would be grate we are going on a long trip next week and need to get it figured out
Awenta
4,090
Take a complete log of a few runs and post them up
5,088
683
Tq referance, rpm, throttle position, rail pressure actual and desired.
You are doing your own tuning right?
3,781
355
I would log MAF value as well. If it is doing it on the stock tune, that points to something mechanical. 20% over injectors shouldn't be enough to mess with the stock tune at all.
Which brand injectors did you go with? I presume they are VCO, since SAC injectors start at 40% over or so.
wilsondiesel
190
Sedalia, MO
What should MAF read? I'm having a similar issue with a ZF6 truck. Builds up to 15psi of boost but very slow in low rpm and takes a bit to get wound up. No shaft play in turbo, no boost leaks, holds rail pressure just fine. Replaced MAF with a known good one and the pigtail also. Stock tune, stock injectors with a couple with high balance rates..
3,781
355
It has been so long since I had a stock motor, I don't know anymore :joker:
With MAF and RPM, you can do a calc PID that does cylinder air, which will let you see if the engine is constantly on the MAF limiter table, which is what you really want to know. If it is constantly on the MAF limiter for a stock truck, something is wrong. If it isn't on the MAF limiter, something else is limiting power. It just lets you know if you need to address an airflow issue, fuel pressure issue, etc.
5,088
683
We can't just tell you what the maf should read. That's totally dependent on rpm, fuel, and engine load. Between 13-30psi IIRC is the limit of the sensor. I look more at the curve of how the maf builds, but I've only played with vvts not fixed turbos.
Luvss350
Aug 25, 2017
9
silverton OR
Yes im doing my own tuning and im still learing efi live and up untill now i have not done diesels so im learing a lot and reading a lot of the threads on here.
Luvss350
Aug 25, 2017
9
silverton OR
They are from lincoln diesel specialties
wilsondiesel
190
Sedalia, MO
I've got a log I could email and see what you think. Its not on the MAF limiter the way I'm understanding it. Only reaches limiter once in the log. I feel like something else is limiting the power but just don't see what when it builds rail psi just fine...
3,781
355
Yeah, post up a log and I can look when I get a chance. Might be a few days though for me. If you post it here, anyone with time can help out.
Sent from my S60 using Tapatalk
Luvss350
Aug 25, 2017
9
silverton OR
So i have not had time to get the log but now the truck is dieing at when i stop at a light and is hard to start sometimes im thinking fuel pump?
IOWA LLY
Yes, its really me
Feb 23, 2007
2,275
So It didn't do it before, and now it's randomly dying....
Fix whatever you screwed up while doing the Headgaskets and injectors! Why would the pump just magically go bad?
This fits right in with the "built not bought" thread going on right now. And is a prime example that some things are better left to professionals.
