I'm going to take a wild stab and say the valve train is the same as the LLY's...
If so, thats probably the easiest part... All you do is back off all of the rocker adjuster bolts, then loosen the 5 bolts in the valve train "rail" and it comes off with the rockers and whole nine yards. Valve bridges just sit on top of the valves nicely. Push rods come out nice and easy. Putting it back in you just put the valve bridges and pushrods back in the same spots they came out of, torque down the whole rocker "rail" according to the procedure then use a set of feeler gauges to set your valve adjustment.
I'm not speaking from experience on the installation part because I'm not there yet haha. Only tough part will be rotating the motor so you can set each rocker... but I think you can do them all in two crank positions... just need to know which position is piston 1 TDC intake and piston 1 TDC exhaust. And I think you slide the feeler (.012 or .011") in between the valve bridge and the rocker and then tighten the adjustment bolt down until it is snug, then torque the locking nut.
Here is the adjustment procedure.
http://www.duramaxdiesels.com/forum/showthread.php?t=6154
And this is the "which rocker to adjust in which position" table.
http://www.duramaxdiesels.com/forum/showthread.php?t=6149
