Aeroforce scan gauge will read rail pressure:coolspot:boost and egt gauges are a good start . you can add a fuel press gauge down the road and hook it to the lift pump . im not sure anyone has come up with a rail pressure gauge for lb7's yet , but maybe im out of the loop on that
Really??!!! :cool2:
Fuel pressure is a good one as if you get a 100psi gauge you can use it to monitor drive pressure later if you want.
Does some body make a 4 gauge pod for my truck
I don't think PPE makes a RP gauge for the LB7 yet.
There's also a 4 gauge pod that mounts above the rear view mirror
