Water pump to block oring info
Dozerboy
4,811
393
TX of course
Well I have to replace the water pump and I have a Mahle gasket kit #HS5458A from when I did the HGs on my truck. I’ve been told the O-rings are not inside this kit for the water pump, but there are 2 large orings that I can’t see what else they would be for.
They are about 3.5” in diameter.
This is the only specs I can find on the O-ring I need which doesn’t really make sense to me. Anyone tell me forsure if I have the right ones or not?
4,953
Are they black?
Also can’t think of another area where that large of an o-ring is needed.
ikeG
Oughta Know Better
Apr 19, 2011
2,429
128
Western PA
www.facebook.com
94013304 is OE part number for 01-16. Only other seal close to that size is cp3 adapter to block seal. Y bridge seals are smaller than 3.5".
Sent from my SM-G960U1 using Tapatalk
Dozerboy
4,811
393
TX of course
The orings in Mahles set where for the CP3 while it might have worked you had to stretch it a bit and probably wouldn’t last.
