Turbo suggestions for 7.1 build
Dustin Ellis
Sep 27, 2020
Corpus Christi, Texas
Looking for any input on possible turbo set up on a new engine build, 7.1 SoCal stroker, stg2 heads, 9100 cam, 2.25” headers and up pipes, probably a wagler intake. It will be a hot street truck/ drag racing. Fuel for now will be lly 100overs. I’m thinking FI s476/87/.90 in the valley and something over 100mm as a low pressure turbo later. Open to any thoughts or suggestions. Thanks
gmduramax
Shits broke
Jun 12, 2008
4,047
231
Nor cal
You might be better off with a 96 turbine in the valley. Depending on the rpm range you want to run in, but judging by your 9100 cam you’re gonna be running higher rpm.
Dustin Ellis
Sep 27, 2020
I plan on running up to 5,000-5,200 rpm. The 96mm turbine would be a t6 flange I think, I wonder how well that would spool on the street with a 96 turbine T6? I would think “guess” the big heads, cam and added displacement would help spooling, anyone have experience with that set up? Thanks, any input helps guysI have no experience with even a mildly built motor let alone this monster.
Bdsankey
3,918
1,076
Neenah, Wisconsin
If you're going to be turning 4500rpm+ and trying to be efficient there you either need a 96 turbine (you can get them in tight T4 housings) or a wastegate. @coker6365 has done some pretty extensive testing and noticed that after mid 4xxxrpm (can't remember the exact RPM) drive pressure starts to climb. That's on a FI 472/491 compound setup.
As for 96 T6 on the street, just don't. I did it for Diesel Power Challenge 2019 and it was a bear on the street. Once you got the thing lit it was an absolute riot and a monster but the transient response left alot to be desired. I think that could be resolved with a tight T4 housing but I never ran one to confirm my suspicion.
Dustin Ellis
Sep 27, 2020
Thanks for the input! Talked to FI and they can do a 476/92 in T4, and they have Black Friday sale going. Might be a good balance between drive pressure and decent street manners. Still considering a few other options though.
Bdsankey
3,918
1,076
Neenah, Wisconsin
The 92 may be but I do not have personal experience with them. When you're ready to get something heading your way there are a few vendors on here (myself included) who are FI dealers and can easily get you squared away.
I personally think a 476 is about as much turbo as you have fuel for with 100s. What stall converter? What injection pumps?
Dustin Ellis
Sep 27, 2020
Close to 900 as I can get on single turbo and 100’s then I’ll add another turbo and more injector for 1200 later. At least that’s kinda my plan. I know the longblock is probably overkill for that power level but power is addictive and I’m hard on equipment.
9,903
149
Hopefully the tuner knows how to use a drive pressure gauge and a timing calculator.....
  • Haha
Reactions: Bdsankey
gmduramax
Shits broke
Jun 12, 2008
4,047
231
Nor cal
Your cam is too big for a street truck. When you mentioned 9100 cam I assumed you were going for 1500hp+. I would put a much smaller on in and run a 72/87 and a 91/100 over the top. Easily make 1200 with great street manners.
Dustin Ellis
Sep 27, 2020
My power goal seems to be going up, lol I wouldn’t mind 1500hp at all. I’m gunna drive it on the street regardless.
I used to drive a bbc mud truck with a 308 duration cam, 4500 stall manual valvebody th400 on the street. Loved every minute of it.
I appreciate all the comments, this is my first built diesel hotrod and need some different perspectives.
gmduramax
Shits broke
Jun 12, 2008
4,047
231
Nor cal
Stock block?
