Im gonna change the spin on transmission filter on my dually. what is recomended and how much fluid will be needed? Also how often should the internal filter be changed?
Thanks in advance!!:chevy:
You'll lose approx one pint. The internal filter only needs to be changed at rebuild time. No other service required
That is of course you don't intend to change the fluid.. But if your question is pointing towards a fluid change then the doors are open. Drain fluid and replace with same amount drained. Typically this will be about 2 to 2 1/2 gals of either Dextron III or a synthetic tranny fluid. The tranny itself holds around 20qrts but the rest is in the torque converter and upward in the tranny, changing the internal filter will allow another 4 qrts to drain through.
But as stated use an ALLISON SPIN ON >>>>> do a google for an allison dealer in your area...
Well the truck is creeping up to 60k I bought the truck second hand and i dont now if its benn maintained or not so i figure if im gonna change the filter i might as well change out the fluid and be fresh.
so if im understanding correctly DONT use a generic spin on and go get an ALLISON from the dealer?
If you go to the dealer you will pay out the nose for it. I would recommend finding a Detroit Allison dealer in your area
http://www.allisontransmission.com/locator/mappoint/index.jsp?country=US
Thanks for the link. the closeset dealer to me is an island over
