Absolutely sure you've got the retaining clip seated properly? All three if the little pips are showing thru the holes in the outer fitting?
It takes a bit of force to pop the lip of the line past the clip until it "clicks". On my daughter's Cruze, I used a very small, very light coat of dielectric grease on the cup part of the hose fitting to get it to slide past the clip easier.
