LLY: Torsion Bar is broken....
ShredLordXx
May 13, 2015
92
Northern Ontario, Canada
Well I'm not sure what caused this but I'm guessing it has to do with my plow I just recently put a Meyer 8.5 straight blade on, and my front end sags quite a bit. When I woke up Saturday and looked outside I saw my truck leaning, and when I went inspected it, I found this on the drivers side! I'm almost scared to have the plow now, to always worry about my torsion bars breaking.... Is there anything I can do to help beef up the front end, I was looking at some Fire Stone Ride Rite front air shocks but they cost nearly a grand!
ShredLordXx
May 13, 2015
92
well for one, i wouldnt be leaving the plow up all night letting the truck take the full weight of it.
your also missing all of your yellow jouce bumper
a set of these will help you out alot
http://www.amazon.com/Timbren-GMFK2...p/B001TNHFUK/ref=cm_cr_pr_product_top?ie=UTF8
I always put my plow down at night, or even take it off, that night the plow was all the way down and I had kept it on because it's snowing all week, I found it weird that it broke then, the bump stop is there its just compressed down to nothing. I've heard people say timbrens are good and bad, maybe I should give them a go!
ShredLordXx
May 13, 2015
92
The length is the same not the torque rating.
http://www.gmfullsize.com/tech/torsion401.html
Have you been to this site.?
http://www.letsplow.com/showthread.php?t=2223
Crap! I may have gotten the wrong Torsion bar then, I ordered one off of ebay, the Donor truck was an avalanche 1500 and the lists
his part will fit these makes and models with these options
CHEVROLET 1500 PICKUP 88-98 Front; (model VIN K), L.
CHEVROLET 1500 PICKUP 99 Front; (5.0L or 5.7L only), L.
CHEVROLET 2500 PICKUP 88-98 Front; (model VIN K), L.
CHEVROLET 2500 PICKUP 99-00 Front; (5.7L, 6.5L or 7.4L only), L.
CHEVROLET 3500 PICKUP 88-00 Front; (model VIN K), L.
GMC 1500 PICKUP 88-98 Front; (model VIN K), L.
GMC 1500 PICKUP 99 Front; (5.0L or 5.7L only), L.
GMC 2500 PICKUP 88-98 Front; (model VIN K), L.
GMC 2500 PICKUP 99-00 Front; (5.7L, 6.5L or 7.4L only), L.
GMC 3500 PICKUP 88-00 Front; (model VIN K), L.
SIERRA 1500 PICKUP 07 Front; (classic style, creased Dr skin), L.
SIERRA 1500 PICKUP 99-06 Front; L.
SIERRA 2500 PICKUP 99-10 Front; L.
SIERRA 3500 PICKUP 01-10 Front; L.
SIERRA DENALI 02-06 Front; L.
SIERRA DENALI 07 Front; (classic style, creased Dr skin), L.
SILVERADO 1500 PICKUP 07 Front; (classic style, creased Dr skin), L.
SILVERADO 1500 PICKUP 99-06 Front; L.
SILVERADO 2500 PICKUP 99-10 Front; L.
SILVERADO 3500 PICKUP 01-10 Front; L.
SUBURBAN 2500 07-13 Front; L.
YUKON XL 2500 07-13 Front; L.
But I guess it's not of the same caliber as i figured, but made a stupid mistake...
ShredLordXx
May 13, 2015
92
With a bit of reading though, which really confuses me is that the donor truck is a 2005 Avalanche 1500, and when i looked up part numbers on gmpartsdirect.com they both have the same part number...
FRONT SUSPENSION/FRONT SUSPENSION FOR 2004 GMC SIERRA 3500
15528958 TORSION BAR
ALL MODELS; 4WD; RIGHT
9 15528957 TORSION BAR
ALL MODELS; 4WD; LEFT
FRONT SUSPENSION/FRONT SUSPENSION FOR 2005 CHEVROLET AVALANCHE 1500
9 15528958 TORSION BAR
ALL MODELS; 2WD; RIGHT
hmm
Awenta
4,090
CT
I wonder if the keys have the same part number. The HD could just have more preload
13,598
631
There should be a paper tag on the bar with a two letter code. Here's a list of the codes and associated part numbers with their torque (weight) rating.
CHEVY TORSION BAR CODES AND RATINGS:
15048307-LH (code XK) (Max torque 4553)
15048308-RH (code XK) (Max torque 4553)
15048309-LH (code XL) (Max torque 4626)
15048310-RH (code XL) (Max torque 4626)
15712407-LH (code WX) (Max torque 4863)
15712408-RH (code WX) (Max torque 4863)
15048311-LH (code XM) (Max torque 5638)
15048312-RH (code XM) (Max torque 5638)
15528955-LH (code GF) (Max torque 5826)
15528956-RH (code GF) (Max torque 5826)
15058267-LH (code YH) (Max torque 5913)
15058268-RH (code YH) (Max torque 5913)
15712409-LH (code WY) (Max torque 5913)
15712410-RH (code WY) (Max torque 5913)
15528957-LH (code GG) (Max torque 6707)
15528958-RH (code GG) (Max torque 6707)
15528959-LH (code GH) (Max torque 7161)
15528960-RH (code GH) (Max torque 7161)
15712411-LH (code WZ) (Max torque 7267)
15712412-RH (code WZ) (Max torque 7267)
15528963-LH (code GK) (Max torque 8615)
15528964-RH (code GK) (Max torque 8615)
15528965-LH (code GL) (Max torque 8782)
15528966-RH (code GL) (Max torque 8782)
15732338-LH (code XG) (Max torque 9054)
15732339-RH (code XG) (Max torque 9054)
plowboy_lbz
Farmer
Aug 6, 2013
431
The plow set ups I've seen use suspension stops on the front to basically make it rigid when the plow is up.
ShredLordXx
May 13, 2015
92
Yeah I will probably buy some timbrens, to help the sag, but I don't have the donor part in hand yet, just pictures. and I don't see any of those codes on it, I am worried that the donor 2005 avalance 1500 torsion bar will not be good for the 3500, even though they have the same part number on gmpartsdirect.com
ShredLordXx
May 13, 2015
92
Well I think i found my answer, if you click on other suspension parts in gm parts direct i can see the 1Ton torsion bar for the 3500 which is this guy
So i guess i definately bought the wrong torsion bar!:mad:
Manufacturer: GM
Part Number: 19330060
Part: TORSION BAR, LEFT
Part Notes: 4WD, 1 TON
Tothemax
xgmtech
Oct 16, 2014
607
new york
Don't think you should worry about the plow. Think the torsion bar just hated life. I have a fisher v plow with the keys turned all the way up for over 4 years no with no issues.
