Tips to install new exhaust manifolds and up pipes
firechaser1141
Jan 31, 2017
14
Hello all I'm about to start swapping out my exhaust manifolds and up pipes. My factory up pipe blew a baffel so I'm going ahead and changing it all out. Dose anyone have a list of bolt sizes and or and special tools that may make the job a bit easier, I know the up pipe bolts are 12pt 12mm but that's it.
OregonDMAX
NOT IN OREGON, NO DURAMAX
Apr 28, 2013
3,964
35
Goodyear, AZ
Presoak every single bolt with pb blaster the night before, you will thank me.
And use antiseize on the new bolts going back together Incase you ever have to remove them.
firechaser1141
Jan 31, 2017
14
I've got a really long snap on 1/2 flex head ratchet I was thinking about trying. What size are the manifold bolts and nuts?
rg3whitelbz
Jan 19, 2013
166
Maryland
IIRC I did drivers and passenger side turbo uppipe bolts from passenger fender well and drivers manifold uppipe bolts from under the truck with a 12mm 12pt impact swivel. Manifold bolts were 6 point 13 or 14mm but they were no big deal.
830king
191
Central MN
You going with stock replacements or upgrading?
Sent from my SM-G930V using Tapatalk
OregonDMAX
Apr 28, 2013
3,964
35
Goodyear, AZ
Just finished a set on an lml, fit amazing, look good, well worth the $
Remove uppipe and downpipe heat shields before removed the pipes makes it 1000 times easier.
firechaser1141
Jan 31, 2017
14
So what's everyone's opinion on getting the bolts looses spraying them with a good penetrating oil (wd40) and letting them soak overnight or running the truck up to operating temp and trying to remove them then
1,605
FYI: WD40 is not a "penetrating oil" in the sense that needed here. PBBlaster or something similar is what you need to use.
firechaser1141
Jan 31, 2017
14
The wd40 I have is the penetrating oil with the blue torch technology stuff I've also got liquid wrench I may try not sure yet
Dart.340
Canadian
Aug 3, 2015
30
Near Ottawa
A little tip for the manifolds is to weld the nut to the long studs. That way one you loosen it off it will already be out of the head and make manifold removal easier then having to slide it 2-3 inches away from the head
BlkMax
743
Wasilla, AK
Every time I have done up-pipe bolts I have resorted to using a porta-power jack from the floor to the end of the breaker bar. It's not pretty, but I keeps me from being so out of position when trying to break the bolts from the up-pipe to the turbo loose.
