DTC C0327
Circuit Description The transfer case encoder is an analog sensor that returns a signal that represents the physical position of the transfer case sector shaft. This signal represents the mode or range position that the transfer case is currently in. This sensor is made up of the following 3 circuits:
- 5 volt reference circuit
- Encoder signal circuit
- Encoder low reference circuit
This DTC detects an out of range reading from the encoder signal or a short to voltage on the 5 volt reference circuit.
DTC Descriptor This diagnostic procedure supports the following DTC:
DTC C0327 Encoder Circuit Malfunction
Conditions for Setting the DTC The transfer case shift control module has a predefined range, 0.5–4.5 volts, in which the encoder feed back should stay within. The DTC sets if the encoder signal feed back falls out of this range.
Action Taken When the DTC Sets
- All motor activity stops and the transfer case lock engages.
- The SERVICE 4WD indicator remains illuminated for the remainder of the current ignition cycle.
Conditions for Clearing the DTC
- The transfer case shift control module will clear the DTC if the condition for setting the DTC is not currently present.
- A history DTC will clear after 100 consecutive ignition cycles without a fault present.
- History DTCs can be cleared using a scan tool.
Diagnostic Aid Check the mechanical condition of the shift lever detent shaft connected to the motor. If this shaft has too much mechanical play this can cause an under voltage or over voltage from the encoder causing the DTC to set.
Test Description The numbers below refer to the step numbers on the diagnostic table.
[*]This step checks for a voltage reading on the scan tool.
[*]This step tests the encoder circuit for a current malfunction.
[*]This step tests for an internal encoder malfunction which is present only in certain areas of the encoder sensor.
[*]This step tests for proper reference voltage at the encoder.
[*]This step tests the 5 volt regulator encoder circuit for a short to voltage, short to ground, an open or high resistance.
[*]After determining if the reference voltage measured in Step 4 is correct, Step 6 reviews the reading originally measured in Step 3 to see if it is higher or lower than what is expected. This step helps determine whether the encoder signal circuit is being pulled high or low.
[*]This step tests the encoder signal circuit and the encoder low reference circuit for a short to voltage.
[*]This step helps determine a faulty encoder.
[*]This step tests the encoder signal circuit and the encoder low reference circuit for an open or a short to ground.
DTC C0327 Step
Action
Values
Yes
No
Schematic Reference: Transfer Case Control Schematics
Connector End View Reference: Transfer Case Control Connector End Views
Did you perform the Diagnostic System Check – Vehicle?
Go to
Step 2
Go to
Diagnostic System Check - Vehicle
- Install a scan tool.
- Turn the ignition ON with the engine OFF.
- With a scan tool, observe the different voltage parameters.
Are the voltage parameters displayed?
Go to
Step 3
Go to
Step 5
3
- Start the engine.
- Set the park brake.
- Place the transmission in Neutral.
- With a scan tool, observe the Encoder Return Voltage parameter.
- Select each of the mode positions.
Does the voltage reading stay within the specified values?
0.5–4.5 V
Go to
Testing for Intermittent Conditions and Poor Connections
Go to
Step 4
Does the voltage reading stay within the specified values at any position?
0.5–4.5 V
Go to
Step 11
Go to
Step 5
5
- Turn the ignition OFF.
- Disconnect the encoder motor.
- Measure the voltage from the 5 volt reference encoder circuit to a good ground.
Does the voltage measure within the specified values?
4.8–5.2 V
Go to
Step 7
Go to
Step 6
Test the 5 volt reference encoder circuit for a short to voltage, short to ground, an open or high resistance. Refer to
Circuit Testing and
Wiring Repairs.
Did you find and correct the condition?
Go to
Step 13
Go to
Step 12
Was the voltage reading measured in Step 4 greater than 5.2 volts?
Go to
Step 8
Go to
Step 9
Test the encoder signal circuit and the encoder low reference circuit for a short to voltage. Refer to
Circuit Testing and
Wiring Repairs.
Go to
Step 13
Go to
Step 12
9
- Using a fused jumper, probe between the 5 volt reference encoder circuit and encoder signal circuit.
Is the Encoder Return Voltage parameter within the specified values?
4.8–5.2 V
Go to
Step 11
Go to
Step 10
Test the encoder signal circuit and the encoder low reference circuit for an open or a short to ground. Refer to
Circuit Testing and
Wiring Repairs.
Go to
Step 13
Go to
Step 12
11
Replace the encoder sensor. Refer to
Range Selector Position Sensor Replacement.
Did you complete the repair?
Go to
Step 13
12
Replace the transfer case shift control module. Refer to
Control Module References for replacement, setup, and programming.
Go to
Step 13
13
- Use the scan tool in order to clear the DTCs.
- Operate the vehicle within the Conditions for Running the DTC as specified in the supporting text.
Does the DTC set?
Go to
Step 2
System OK
