Stock LB7 Pistons
chevytuf01
Dirty Deeds
Jul 2, 2010
261
Rileyville Virginia
Im about to start a motor build and im wondering what kinda power & durability everyone is seeing/making with stock LB7 pistons & Carrillo Rods ?? This is going to be a sled pull motor only
MAXX IT OUT
<<<IT WORKS
Mar 1, 2013
1,774
Des Moines, Iowa
What class???? If it is a dedicated puller I would to cast or forged, cause you will be back in the engine after a while to replace them. I see delipped lb7 piston working better in a street truck and occasion puller or racer, but i don't see them holding up for a long time in a dedicated puller.
blk smoke lb7
<-----Lots of green $
Nov 8, 2010
5,694
57
belvidere,ill
I am stock deliped and coated b7t my pistons have a time limit id probably do fingers pistons because they have more material next time.
dmaxbowtie
Duramax fiend
Jun 2, 2011
228
RI
I chose fingers because I drive a lot on the street and put a good amount of miles on, but if I were strictly pull/race I'd go forged
rfletes79
636
125
Galt, Ca 95632
We ran a set of delipped LB7 pistons in my Chevelle this season with triple 66's. making upwards of 90 psi of boost. We put about 100 passes on them then they started failing. Burnt/cranked one in early sept replaced it and hit the track again only to break another. They worked well but have their limits. Never ran an EGT gage so we have no idea what we were running them at. Ran an A/W IC with intake temps starting at about 60 degrees and climbing to about 175 by the end of the run.
With a good supply of factory pistons that you could swap out when needed you'd be good to go. If not just spend the money, it will be well spent.
ripmf666
15,123
14
47
Wentzville Mo
Ever since the Mahle Race Cast pistons came out that's all I sell. Only things I sell the OEM pistons for is stock rebuids or very mild builds using Lbz rods.
These pistons make it so nice with there options. All while having a wider bowl and keeping comp were you want it still without. Dropping off a lot when needing valve pockets. Also no strength lost from deliping these like stocker. So all gains across the board and skirt coating to boot.
thicker crown, more material between the bowl and the gallery, more material in the cross section below the pin bore.
Utahski
Oct 20, 2008
546
Northern Utah
I did some careful measuring off the pin of a Mahle Cast Race piston and an lmm piston. The Mahle bowl is .120" thicker..... about 1/8", and a bit wider, plus de-lipped. You can also see more meat underneath the internal oil coolant passage. They come either flat or with valve reliefs. It's a beautiful piston, my engine has them. Wonder if any have broken.
ripmf666
15,123
14
47
Wentzville Mo
As far as I know not that I have heard. Fingers uses the same Mahle race cast but in blanks to make his pistons also. So there holding also aswell so Mahle did something right with this piston for us.
