Gonna be building the lbz and was wondering about the stock crank. Is it gonna hold up? What needs done to it to help go along with the build?
Cryo does nothing for the strength and most certainly will not relieve the stress. Cryo is only helpful while the crank is being made and then it can be ground to tolerance.
Depending on how much power your going to lean on it with. I would make sure you have about .0028-.003 clearance in the main bearings too. I believe under the added stress, it's helping the crank flex a little, squishing out the oil jacket and then it makes contact with the bearing (caused my spun bearing I believe because I could see the contact marks ).
Has anyone broke an lbz or lmm crank yet? Just wondering because of miles and abuse before the build. Alot of the big hp trucks seem to have lb7 cranks and was wondering if your gonna do a build if you'd be better off getting a new crank because of fatigue? Just thinking out loud.
