A thread for everyone's amusement...
Evidently the bottom bolt fell out and then the starter mount plate cracked right under the top bolt hole and it fell out. It was off once before, replaced under warranty a bit over a year ago. Got a reman from carquest and ate the core charge so I could keep this one, not like it was worth anything for core with a broken mount plate anyway. Dad's starter has been zinging sometimes so I figure my starter was good, I can take his front plate off and swap it onto that starter and put it on his truck. I had a metric bolt that was about the same size but I had to grind some off the end to make it go in enough. I assume that's because of how the other bolt had the threadless part on the end, fits into a hole? Anyway got it back together today when the starter came in. Tight fit in there...
