I'm trying to script a tune and when I try to compare the two tunes it says I can't because the o.s. is different. I thought you had to have the tunes side by side to script. Can anyone point me in the right direction? Very new to this. Thanks
after you have did the compare feature of 2 (same op system) tunes you click on edit, then create script.forgive me for being so new to this , but is there a script button or something????/
so your saying that the vehicle you run/put a script on has to have the same fuel tank size or it won't work?
But if the script your running was from a truck with a different fuel tank it will change it when you run the script. You just have to change it back.
No it won't. A script only changes what has been changed from the tune you are comparing. In other words, when you create the original tune, as long as you don't change the fuel tank parameters from stock, they will not be included in the script.But if the script your running was from a truck with a different fuel tank it will change it when you run the script. You just have to change it back.
If you use a stock tune with a 34 gallon tank, and the alternate tune you are using to create the script also has a 34 gallon tank, you can use the script to make a tune for a truck with a 26 gallon tank without doing anything to the fuel tank parameters. If any table is the same in the original tune as the alternate tune, that table will not be included in the script.But if it was built off a 3500 and the tune is that of a 3500 it will have the Fuel Size in the script since your going over a 2500?
I'm I making any sense?
