Safe tune , towing 10,000 lbs.
77cruiser
103
5
Frost Bite Falls
What's a safe tune for towing a 10,000 lb. trailer through the mountains?
I have a PPE tuner, & I have it on 120 hp now but was going to go with 90 or 50.
Have NO pyrometer BTW, if I did I'd leave it as is.
2004 LB7
IOWA LLY
Yes, its really me
Feb 23, 2007
2,275
This^^^^^^ 50 at the most of you truly want to be safe.
Dozerboy
4,812
394
TX of course
Is this a once and a while tow or everyday? If its later get a Pyro other wise just lock out the OD. Your trans is more an issue then egts.
2008lmmchopper
May 28, 2017
275
Ya I'd set it at 50 buddy. I tow on a 60 hp tow/eco tune and ive never had an issue.
Sent from my STV100-2 using Tapatalk
Dozerboy
4,812
394
TX of course
But your 6sp trans is stronger then his 5sp so what you do doesn't apply to him.
77cruiser
103
5
Frost Bite Falls
Well I put it on 90hp, usually drop it to 4th on a good grade. Haven't seen any temps higher than 11-1150 till I got up to around 6000ft & I saw a few times 1200.
Had to have some work done a G&J Diesel in Billings. The shop guy said he's seen some higher temps with stock tunes.
oscyjack
May 7, 2016
775
Northeast
I'd keep it at 60ish or below and tow sensibly and you should be good. When I was on a stock trans that's what I did with 6th locked out and a turbo brake.
torqued2dmax
646
Brookville, PA
Till your on a hill and here comes a 20 year old Cummins , fenders flappin , bed sides ready to fall off , he is towing the same weight , can you keep from up shifting ? LOL!
