For those that have regeared. Do you typically get the master install kit or the mini install kit? My truck only has 108k on it and there is nothing wrong with the current gears. The master kit is pretty spendy since it includes new bearings. The mini install kit does not include the bearings and is considerably cheaper. I don’t see the need to spend the extra money since my current bearing are in good shape. I have a press and bearing separator so I should be able to remove the old bearing without damaging. I guess if its common practice to get the master kit that’s what I’ll do. I’m just struggling to spend the extra $$$ on bearings since mine are fine.
I’ve found some pretty good write ups on the rear axle but haven’t found much info on the front axle. Can anyone pint me to a good write up / DIY for the front 9.25??
FYI going from the factory 3:73 to Yukon 4:10. Like to get a little low end back.
Thanks!
Thanks!
