So I have a couple injectors with +/- 6.0 at idle and rail at idle is 12k should I be concerned or no?
you cant check balance rates with a raised rail pressure like that. it will throw balance rates way off. put a stock tune in and see what they are. if you give us the main injection rate, it will help with where the injectors are even with the higher pressure.
if its surging, log it and post the log.
does it only happen with on cruise control or when you just hold the throttle steady? this is a large injector issue from the sounds of it. have you discussed this mark? did this start after the 200% installed or some time after?
sorta. really need to see the log of when its surging. was it surging there?
It's hit or miss I'll log it when it's doing it and post it, how did the injectors look?
was that on a stock tune?
