Pulling bed by yourself
WVRigrat05
Wound for sound
Jan 1, 2011
3,081
French Creek, West Virginia
So, trucks been parked, it's up for sale (which it probably never will), and I want it spotless again, when I pulled the bed on my LLY, I did it at the rig with a forklift but that's not an option nowadays.
So how have you guys been pulling the bed on your own? I was thinking some long straps and a snatch block but not sure how that will work.
FC5452
301
Eastern PA
Two people can pick it up, can't ya get a buddy, a set of horses, and two 2x4x10 and set it down?
Otherwise you could try straps and grab it that way
Burn Down
Sep 14, 2008
7,093
Boise Idaho
By myself I would use 4 straps or chains to the inside hooks of the bed corners, use a comealong from the rafters or a tree and lift it up and pull the truck out.
six5creed
1,046
58
N.C.
I pulled mine like Albert said. I strapped it corner to corner cross ways and lifted it straight up by myself with a hoist.
Budneeds2beers
Aka Mike Honcho....
Aug 25, 2016
497
Cali
If you have a steady branch throw a strap over it and tie some lifting tackle (pulleys ect...).run a sturdy 2x6 or double stack 2x4 for more back bone under the bed rails. Slowly lift bed to find center and viola! How i did mine by myself. Use as wide of a piece of wood under the bed rails so you dont bend them.. hope that helps
TLyons90
Apr 22, 2013
1,631
Greenville, SC
I considered pulling the bed on my last truck. My thoughts were back under a tree or 2 with some good size limbs. Hook 4 tie down straps to each hook inside the bed. Then 1 bigger strap in the middle that hooked to the trees. Then ratchet up on each until I could drive out from under. Not sure it would work... But my help!
1,601
It sometimes pays to have a teenage son with friends. ;)
But I like the way Burn and Slim did it.
02greysixer
1,829
North Central FL
Full redneck here. Big branch, snatch block and a winch. Strapped the bed like everyone said
Sent from my SM-G930P using Tapatalk
WolfLMM
Making Chips
Nov 21, 2006
4,005
25
AL
Love this! Y'all would shit a brick if you've seen some of the ways I've done things.
I have lifted my whole truck with 10ton overhead crane, and worked under it. I did park two 6000lb forklifts under each end to act as a life saver:thumb:
As far as lifting the bed, I've always used a 4x4 cut to length under the bed rails, find center of gravity and lift. If worried you can always C clamp the 4x4 to the bed rails using 2x4 block on top to keep from reforming the bed rails.
