Is there anything special that should be done after head gasket replacement? Be gentle for X hours or miles? Run it hard and let it cool off?
if you did it yourself how hard was it
Based on my experiences only, I do the obvious road test and let it got through one heat cycle. The next cold start if everything sounds normal then I drive it normal. I am however cautious of the coolant level. These things take about 800 gallons and hold a ton of air even if you have the bleeder open. Some birp right off the bat then some dont for a while. I know mine was almost a month before it stabilized. I dont have the bleeder to use though. We also had one at the shop thats been done for a couple months and he came in complaining of coolant usage. He added about a half gallon. We figured it just birped again.
800 Gallons? Man thats a lot off coolant . When I did my coolant flush I bought maybe 4 gallons. My coolant must be way low.
:happy2:
That being the key word here, dont you have some hookup at the dealer?:rofl:
Im sure the more you do the easier it is as well. I just had a local diesel shop do mine. Book time is about 32 hours. They had my truck for a month due to waiting on parts, getting heads tested, replacing a valve and guide, etc etc. It is definitely a lot of work from what i have heard. There is A LOT going on under the hood haha
Dude... Book time must allow for a lot of problems... From the time I parked the truck to the time the motor was on the stand stripped to a shortblock was about 7 hours of work... and about an hour of that was assembling the second engine stand and running to sears when I broke my 1/2" drive "breaker ratchet" trying to get the crank bolt off... The I proceded to break a "real" 1/2" drive breaker bar in about 30 seconds... When I bought it, my buddy was like "If you break THAT I'm buying you dinner".... Yeah, 30 seconds in, snap! :rofl:
