I have been told there is a plug on the pass front of the block where I could tap oil from. I have been told that it is metric pipe thread. Does anyone know exactly what thread it is?
Why do the simple things become a project:rofl:
if it's similar to the one on the ds it's actually just an a/n or jic o-ring thread.
Metric pipe thread? I was a honda/acura tech for 10+ years and they even used standard (sae) pipe threads for any tapered application..
FWIW, the threads in the oil filter housing are supposed to be British pipe thread. I have my oil temp gauge sender and lift pump switch threaded into it with NPT bushings, no leaks. 2+ years..
:dontknow:
Straight thread or tapered?
On edit i believe it is a 14x1.5 ( best to ask the expert, Henry)
straight or taper its a 1.5 pitch that is all you need to know.
1.5 tells how far apart the threads are. Could still be tapered or straight. If its tapered it just needs pipe dope. If its straight it will need an o-ring or some kind of sealing washer.
Does the stock plug have a seat and an o-ring or just some dope on the threads?
Stock has a brass crush washer
Hmmmmm.....now I'm wondering if I can just drill a hole through the stock plug and weld the correct fitting to it
I use a brass washer witht eh O-ring inside of it and they never leak
Paul it's 6 bucks......you cheap bastard! Maybe if you got a steel one it would only be 2 bucksoke:
