i dont know what this part is called to describe to the dealer. To get them dumb arse's to give me the right o rings. http://www.youtube.com/watch?v=pbInFVytjcQ
Thanks man so much.
rick pro fab
Its a pain to get in there. If they blow again by some 236 size orings, youll prolly get them both for about $1.50
Next time mine blows out I'm gonna reinstall it and get it clocked right and drill a hole in the top of the bridge through the horn and tap it. Hopefully a bolt will hold it in there... IDK what GM was thinking with the slip fit
All of the support holes lined up except the one behind the alternator. I used rotella for lube and a flat head and a hammer to beat it back in. I think i get it in good and soon as the vanes open and close on start up u can hear it leaking. That thing is a pain in the rear something terrible.Once you got Ricks egr delete on did all the supports holes line up ? Like Josh said alittle lube helps alot on getting her in there.Might need to clean the inside lip alittle on both parts also to help it slide in.
Hahahaha....you bastardOnce you do it like this it will not go anywere lol
