P0101 is not a maf code, but instead it is a mass air fliw outside of the desired range code. P0101 is hardly ever a maf code. It's normally set by aftermarket air filter/boxes, air leaks in the intake tract, maf installed backwards, or something that has altered the amount of air going into the engine like an intake leak, boost tube leak, egr valve flowing when it shouldn't, or an engine problem altering how much air the engines pulling in. You need to know howmuch air flow it is readi,g when it is setting the code, determine how much it should be flowing, and find out what is causing the difference.
