Did some testing yesterday for my P0093 (finally). I just have a couple of things I'd like your input on.
At idle, FRP was around 6000 psi. When commanded to increase, it just laid there dead on/around 6000, no change. Weird. Anyways, diagnostics led me to the high pressure side testing, and the bottle test.
Left bank & right bank both returned 8ml in 15 seconds. Looks like the injectors are okay, right? Still doesn't explain my problem though. Tested again, same results. Hmm. So I measured the return on the injector pump, and it returned 28ml. I looked for a spec on this but didn't find one.
I did find a "total return" spec, which I think was 26 or 28ml? Does this sound right? I believe I have a bad injector pump. Just wanting to know if you guys agree before I spend the cash.
