Something like this bad boy:http://m.summitracing.com/parts/trd-1222
A small block chevy kit would work just fine. My 6.5L diesel used the same filter as most small block chevys did, and I swapped over to the DURAMAX filter on it with no problems. The big difference between the small block chevy filter and the duramax filter is the thickness of the filter(and the DURAMAX filter is about an inch taller and about 3/4 of an ich larger in diameter). The thread is the same, and the size of the sealing o-ring was the same as well IIRC.
I would be a little concerned about the fitting and hose size, doubt it flows enough for the Duramax engine.
So essentially what you are saying is I can run a duramax filter on an sbc engine and it will work fine and be OK. If that's the case then awesome because I can get oem duramax filters for next to nothing compared to a crap brand aftermarket sbc filter.
Depends on which small block filter you get. I have some out in the shop that are the same exact size as the DURAMAX filter, but they weigh half as much from the thinner housing and less filter media. Then I've bought other brands where the filter for a small block was smaller in height and diameter.Diamter wise the two filters I had were the same, so I can't seem them wasting space inside with no filter element. I could be reading what you said wrong though.
Hose is small and I would never use that style hose connections on something as important as engine oil. SS braided at the minimum IMO.
