New mods... very pleased
NRA223
May 20, 2015
288
After a lot of debate and uncertainty about the gains i pulled the trigger on WC Fab 3" Y-bridge, WC Fab 3" boost tubes, and PPE manifolds & up-pipes. I have been worried ever since i bought them that i would be unhappy with the results but man am i glad i did. The turbo spools MUCH faster. I highly recommend these improvements to anybody on the fence about this. :thumb:
Awenta
4,090
CT
I'd recommend profab but I'm glad you're happy
NRA223
May 20, 2015
288
I wouldn't know on that since my edge probe decides when it wants to read correctly or not. But the difference in spool up is definitely noticeable.
jlawles2
1,044
33
Danbury, TX
Jumping to 2000 sounds like a broke wire in the sensor. Had one do that and it turned out to be the wire was broke right at the crimp between the stainless braid and the probe. Found out that you need to fix the feed wire for the probe to the engine and not let it vibrate. Had nephew's truck do the same thing. His EGT probe wire was tied to the firewall.
Awenta
4,090
CT
You can tie it like that just make a loop whenever you leave the motor and go to something solid.
