LLY: New cowl hood!
kman2468
Old Man Truck
May 3, 2009
374
32
so i know a lot of you guys on here are mostly about HP adders and all that but i havent posted on here in awhile
id just like to show my new hood
i have a 04.5 LLY
and i wasnt to fond off the grille. so i decided to buy 06 grille and 06 cowl hood. i am very happy with the way it turned out!
and it came from the company with dents in it. but i am thankful that my neighbor owns a body shop and doesnt charge me anything!!!
but heres the pics
let me know what you think?
gl4787
<-- just sits
Jan 27, 2009
274
WI
U need wheels and tires now dude. And u should level ur mirrors. If u need some help I just did mine.
kman2468
Old Man Truck
May 3, 2009
374
32
i got other problems on truck lol.
and im in college
was that you i saw pulling out of tonys driveway?
13,599
633
im not gona lie it looks stock just my 2 cents
No offense, but if you can't tell the difference between that cowl hood and stock, you might want to schedule an appointment with your optometrist. Just sayin'...
05greendmax
dyno and drag numberssoon
Dec 26, 2009
435
ohio
i know its not stock it it just dont look much different not bad lookin at all but to me it dont look that much different just my 2 cents
kman2468
Old Man Truck
May 3, 2009
374
32
if i had an 05 hood and grille before. i wouldnt of updated. but seeing as 04 doesnt match with 05 and up i wanted to go cowl
maine04max
Dec 11, 2008
1,009
How do you level the mirrors
copied from DP for those that dont go there
1. Remove the plastic cover that is covering up the hinge part. Be careful
because that piece of plastic has a sharp edge; I cut myself the first time
I pulled it off.
2. Inside you'll see 4 phillip screws that is holding down the hinge; remove
these and let the mirror hang down.
3. Take the hinge clamp off from the mirror post. The clamp is what the
phillips screws go through and the mirror post is what the clamp goes
around.
4. Cut each side of the hinge clamp right in the middle.
5. Bend the top of the hinge clamp at the screw hole inward
such that at the cut it is bent outwards the same thickness of the metal
itself.
6. Bend the bottom of the hinge clamp at the screw hold inward as well
such that at the cut it is bent inwards the same thickness of the metal.
Note: Steps 5 and 6 may be confusing but visualize what you
are trying to do and it'll make sense. The reason for
making these bend is such that the mounting surface
where the clamp meets the mount base is square.
7. Insert 3 washers between the top of the hinge clamp and the mount base
and get some longer screws in which to secure the clamp. The washers
about the thickness of a penny. The new screws on top were about 15mm
in length.
8 Trim the plastic cover a bit where you see it rubbing.
im not going to take credit for this it was posted by a guy named reyb on dp
http://www.dieselplace.com/forum/showthread.php?t=104356&highlight=level+mirrors
