so long story short 2010 LMM comes into my buddies shop for a lift pump PPE to be exact. After fire up the truck had injector rattle and lope. Checked RP and it was commanding 4,351 actual was roughly 10,000. Verified psi at fuel filter housing was good, it was 11psi. We changed fuel filter. At idle rail pressure is 10,000 but reving in park or drive actual follows commanded to 19,000 psi but truck won't command over that. Truck runs really shitty. Then we thought it was the regulator... maybe should got through and is causing it to stick? change out with a brand new LMM regulator no change. Thinking rail pressure sensor has failed? balance rates at idle are 0.x with one being 1.x so there doesnt appear to be an issue there. Kinda lost.
