Need some help please!
Installed a new Airdog, All the lines are going to the correct places, followed the installation instructions, triple checked. Primed the pump, started the truck. It ran for about two minutes then shut off. Was able to get it started again for about a minute again, but since then could not get the filter head to prime.
Searched around, figured I would try rebuilding the filter head, as the truck has 98k. After a new rebuild with new fuel filter, (new seals on correctly) pumped the filter head about 400 times, have fuel coming into the filter head, even bled the bleeder screw still cannot get it to hold prime and even start.
Now, with my Fass on my old truck, there was a black oring that went onto the pickup tube of the fuel filter on the liftpump itself. I noticed that the airdog does not have this, only an oring on the outside lip. Not sure if it is supposed to be like that. And if it is not, is that the cause for my problems?
Truck is a 2013, still has the CP4, for now.
Thanks in advance for the help!
