alright so i just installed a lbz cp3 with modded rear cover and modded regulator on my 03 lb7. i fixed the high rp at idle with b1010, but ive got some slight surging in overdrive about 50-60mph. does anyone know what tables to adjust for this?
the question ive asked has no relevance to my sig. if ive got a modded fpr and lbz pump, obviously its not stock.
What tune is in it?
I'm having this issue with my truck as well as my buddies and I am running a modified PPE tune and he is running an unmodified ppe tune. He does have a bad regulator so we will be addressing that first.
i just went through this. Make sure you B1010 table is smooth. When i first put my LBZ reg in i only adjusted the first 3 numbers. between the 3rd and 4th number there was a big diffrence. I had to smooth the table by changing more numbers. Some only say to change the first few thats what caused my problem. Now that i changed more its gone.
Might want to look at a stock lbz tune and yours in the b1010 area
LBZ actually allow less fuel than a lb7 but the ports on the reg are different so I assume that is why.
you might try raising the b1010 value in the area that is giving grief
LBZ has a LOT less entries in the table (B1015, right?). My guess is you'd have to put the LBZ values in as close to the same poisition on the LLY table ( except WOT area), and smooth out the spots in between... Am I on the right track? I think I've got an idea how to fix it with logging, but I can't experiment until I get my trans back in (HOPEFULLY Friday/Saturday).
I wouldnt change it a WOT or you are just loosing what you gained by adding a lbz reg.
Maybe I'm just not understanding things right... The idea of the modded regulator is to allow more fuel to flow, because the stockers tend to become a restriction when you're running high PW. The way I understand it, and from looking at logs on my truck (I've had rail pressure problems for a while), with a stock or failing regulator, it keeps commanding less and less mA to flow more fuel trying to get to where it wants to be, but due to the stock or failing reg, it can't get where it wants. Enter the new modded regulator that CAN flow what is needed. Now if the ECM wants X mm3, which the original just couldn't supply, but the new modded one can, it just needs to know how many mA to give to get the right amount of fuel. Along with that, it's flowing more fuel, so at idle, it needs more mA to flow less and be where it wants to be. Since the modded regulators flow more fuel at the same mA as the stockers, we need to adjust them down so it's getting the fuel it wants, right?
