Max piston protusion
Stingpuller
The Pusher Man
Jan 11, 2007
2,019
35
central Ohio
Deck height on pistons
Mine are out .028" I run the grade 5 gaskets. I fill that you want the piston as close to but not touching the head as possible. I don't agree with just decking the piston to kill compression in a motor. Jeff
sweetdiesel
That's better
Aug 6, 2006
10,390
51
Thailand
Grade 5? how thick is that?
Grade C i read compressed are 0.0394 and I need to double check but i think the piston is 0.013 above the deck
how much play do i safely have?
Had to edit
WolfLMM
Making Chips
Nov 21, 2006
4,005
25
AL
I think your okay! Im no engine builder though. But a thou and three tenths ain't that much lol.
Josh2002cc
That Uncle
Apr 2, 2007
1,832
Grade C i read compressed are 0.0394 and I need to double check but i think the piston is 0.0013 above the deck
how much play do i safelyhave?
You can be out .0129 - .0149 when using grade c gaskets (GM spec) grade b gaskets is .0109 - .0129, and a grade is less than .0109. :angel:
Put that in your pipe and smoke it! Your :welcome2:
S Phinney
4,011
Quncy, Fl
Make sure you check valve to piston clearances when making these type of changes in your motor build. You should have mininum .050 and .070 on intake and exhaust valves respectively. If you use aftermarket cams and deck the heads and block machining valve reliefs in the pistons would be necessary and these clearances are a must do item.
Josh2002cc
That Uncle
Apr 2, 2007
1,832
I believe it is more like .080 on intake and .100 on exhaust minimum. Remember this is not a gas motor :D
9,903
149
Henry, do you have thicknesses of each gasket type?
