i have a 03 lb7 duramax and i was hauling a load of hay (about 20000 lbs including trailer weight) and was running great, pulling fine, and my oil pressure warning light came on when i would drop rpm to idle and then go away when i would give it some gas. oil level is right on the money i hooked a mechanical gauge to it today right off the oil filter housing and the gauge and dash were reading very close 1-2psi off each other. it drops almost to 0 at idle. Oil was changed 1500 miles ago with rotella 15-40 and lucas oil stabilizer, no fuel or water in oil. I'm thinking my mains may be worn but not sure. i will send an oil sample soon but i am just curious if anyone else is having this issue. any input is greatly appreciated:thumb:
