I'm curious what the guys that build these engine are using for ring end gaps? I've got an 07.5 LMM +.020 bore, stock cam & heads, EFI LIve tuner, EGR delete, 4" exhaust, stage 1 turbo upgrade. I'm using Mahle cast performance piston # 930036075 that comes with rings # S42160.020. LMM +.020 bore, stock cam,heads & injectors, EFI LIve tuner, EGR delete, 4" exhaust, stage 1 stock turbo replacement. This is a cab & chassis with flat bed towing a 32' trailer some of the time. The guy at Mahle said .025" but that would depend on my application. .004"-006" x 4.075" so that could be from .016"-.024" but also I've read where Fingers suggested in another post
"0.012"-0.018" on the top ring. Open up another 0.005" at most for severe hot rodding, but no more. IMO
0.020"-0.025" for the second ring. I prefer to keep this one tight, but philosophies vary here. Keystones seal better with less inter-ring pressure. Or so I am told."
Suggestions?
Suggestions?
