LML catalytic converter installation procedure
r_olsen
AZDmax
Nov 4, 2017
Arizona
I have a 2012 Denali 2500HD that I have to get back to being emissions compliant, I live in AZ. I've already installed all the egr valves and coolers, so now working on the cat and DPF, spent a couple of hours today trying to get the cat in but not having any luck, I jacked up the transmission and removed the crossmember but still no luck, just wondering if anyone has the install procedure for this??
r_olsen
AZDmax
Nov 4, 2017
Arizona
thanks for the replies, guess I'll give another try tomorrow. One option may be to cut the pipe about a foot in front of the cat, then splice back together after its installed...? Any drawbacks to do this??
Ne-max
I like turtles
Nov 15, 2011
3,361
Lincoln, Ne
I believe that it would never fit from the back unless there was no axle at all.
Sent from my XT1585 using Tapatalk
That's what I'm saying. The cat is the short piece with the injector in it. Why would taking out the rear shock help? Lol
ikeG
Oughta Know Better
Apr 19, 2011
2,431
128
Western PA
www.facebook.com
Yep.
Op, to reinstall the front pipe with the regular cat, you will need to do what I said in post # 7. Then, if installing the dpf/doc still attached to the tailpipe, you have to bring it in from the passenger side in front of the axle. Snake it up and over the axle. That part is pretty difficult. One of those jobs where you have to hold your mouth just right and it goes in. Will help to jack up on the hitch if the truck is on the ground. Or if on a lift, it's already at full extension
r_olsen
AZDmax
Nov 4, 2017
Arizona
Thanks for all the help, but no luck today, spent a couple of hours scratching my head and wrestling with this thing, I can get in but only with the bend at the front, where it attaches to the downpipe, either facing down or to the side but cannot get it to rotate around so its facing up. The hangup appears to be at the crossmember that is just behind the transmission crossmember, which I removed, does one side of this other crossmember need to be let down? :confused:
NC-smokinlmm
<<<Future tuna killer
May 29, 2011
5,066
265
At Da Beach
There is no way. You will never fit the elbow that connects to downpipe past the torsion bar mount. Even at that the cat won't fit also.
Your right. I just went back and looked at my old pictures. We took the dpf and tail pipe out in 1 piece and doc separately. I remember jacking up the trans now.
r_olsen
AZDmax
Nov 4, 2017
Arizona
Thanks for everyones input, I got the cat installed today, it does just take a lot wiggling it just right, I did jack the truck up at a slight angle from just under the passenger side rear door that seem to help, but like others have said you just need to wrestle it in.:)
