Leaking Coolant
dmaxbitt
Hook 'Em
Mar 22, 2012
23
Fort Loudon, PA
Don't laugh folks, but I have coolant pooling under my truck immediately after I park...but then stops. it's not alot and at first i thought it was just from the AC. It's coming from right above the skid plate...could it be a hose? I still don't have much knowledge on diesels...learning as I go...
Kappa9012
MAN.... I Broke it again.
Aug 5, 2008
694
Peoria Il
which skid plate??? I would crawl under it and look for traces of coolant to see where it's coming from. Narrowing it down to a particular region helps out a lot.
dmaxbitt
Hook 'Em
Mar 22, 2012
23
Fort Loudon, PA
The forward most skid plate right under the engine. Is the oil cooler right there under the engine? There's some type of pan.. right in front of the oil pan.
Sent from my SAMSUNG-SGH-I747 using Tapatalk 2
weazel
261
Mason, TX
Double check the hose connections on your egr hoses. I had leaking issues for a bit, then deleted my egr and the leaking stopped..
Kspen90
<<<got turbos?
Jul 14, 2011
1,433
Burleson, Tx
The coolant is coming down the side of it...maybe a seal?
If its coming down from the top of the oil cooler and there's no coolant closer to the front of the truck then its going to be the o ring that seals the coolant pipe coming from the water pump to the oil cooler. I know because mine is leaking in the same place right now :eek: lol. I just haven't done it because I'm going to pull the transmission soon and do some other mods and ill just do it all at the same time.
jc1843
Sep 27, 2009
228
86
So Calf
Look at the radiator lower hose where it attaches to the engine-if it shows stains, or is wet, it is the water pump that is leaking.
redrob
Apr 6, 2013
41
Western Wa.
Look up from the left front of the skid plate toward the rear of lower radiator at the weep hole from the water pump housing- any coolant drips or coolant residue?
dmaxbitt
Hook 'Em
Mar 22, 2012
23
Fort Loudon, PA
Thanks...and very nice avatar:thumb:
dmaxbitt
Hook 'Em
Mar 22, 2012
23
Fort Loudon, PA
Here are some pics....
