Insight PID list?
Dallas S
486
33
Alberta
Simply running out of room for gauges in my truck. Insight looks to be a good option. I need to monitor Engine oil temp an wondering if There is a PID for this? Having 2 boost gauges, egt, drive pressure, and rail psi don't leave me with much options for another gauge
OregonDMAX
NOT IN OREGON, NO DURAMAX
Apr 28, 2013
3,964
35
Goodyear, AZ
I did the CTS from the start instead of gauges because it has 5 PID's and way more compact then 5 gauges would be. Super happy with it.
Dallas S
486
33
Alberta
Can I daisy chain multiple temp sensors (98608)? Will be purchasing insight and the EAS starter kit. Wouldn't mind pre and post oil temp numbers for a while and then swap one sensor to tranny. Even pre and post intercooler for a while would be neat
mreeves23
Big Hog Customs, LLC
Sep 15, 2011
91
Poseyville, IN
Where do you currently have all your gauges? 3 a pillar and 2 overhead cubby? If so there are pods available for above the rearview mirror and below the overhead console. Just installed a quad pod there w/ 3 gauges and an edge insight cs in our 04 LB7 dually this morning. But the Insight is nice to watch, but I do prefer dial style gauges as it's easier to see quickly I think. Insights are nice to help keep an eye on more gauges than what standard 2 1/16" gauges can. Much less room.
JDub
607
Hooper, Utah
I run the CTS in mine as well. Use the EAS stuff to monitor my lift pump, drive pressure, turbo shaft speed, pre i/c, post i/c, and rear airbags. Don't watch all at once, but nice to have the options should I need, also nice to set warning on them, even if you don't monitor them all the time.
mreeves23
Sep 15, 2011
91
Poseyville, IN
Anyone having any issues with the newer EAS external sensors, pressure or temp? I have heard Edge had a few issues w/ pyrometers in the past so just checking. i do like the insights and their capabilities. cknight199, did you have to do anything special to clear the edge pod w/ the dual a pillar pod? Nice setup.
Dallas S
486
33
Alberta
3 on the pillar and 2 in the cubby. Nothing fits in the cubby or above mirror cause of sunroof. Had to mod the cubby to fit the SoCal pod.
I bought the gauge pod adaptor for the insight. I do like how cknight mounted the insight tho.... Hmmm
Cknight199
Aug 23, 2012
1,827
Salt Lake City, Utah
To make my gauges and cts fit I had to cut a mount that the cts uses if you don't have gauges. Sits flush with the dash and looks good IMO. ImageUploadedByTapatalk1380636503.155534.jpg
Pulled apart from the gauges to get a picImageUploadedByTapatalk1380636527.440540.jpg
