To exert the same effort, 50% more than running in 3rd. Pretty tall order unless the track is pretty loose, IMO.
3rd is going 27mph at 4000rpm, which is a pretty good amount of wheel speed, and when the sled starts trying to pull you off the charger, you actually climb up the torque curve and boost curve. In other words, as you buzz along with 27 mph wheel speed, and the sled comes up, you'll go down to 26mph and pick up power, 25 more power, 24 more, 23 more, 22 more,21 same power ,20 same, 19 then finally the power will start to fall.
