High idle on a LBZ
gr8shot
Practically stock
Apr 28, 2009
262
3
Grand Island, NE
I think it has to be under 32*f and the engine temp has to be below about 135*f for it to kick on. If both of those conditions aren't met then it won't turn on.
DirtymaxLbZ2006
Dec 21, 2012
19
The truck will have to be run for about 1 min and your foot can't be on the brake and it should start to high idle
slipclutchms
427
Is there a parameter in the tune that can be changed on Lbz's? I haven't started mine in that cold of weather so I don't know.
derek06
Feb 6, 2012
452
35
massachusetts
To turn it on? Look in your book there is a certain pedal sequence to turn it on and then it high idled automatically at the temp
slipclutchms
427
Haha owners manual.......:roflmao:
You get your trans built yet Derek? My goal of the year is to be able to run with Derek and his stock lbz....thats all I want to do :hug:
ChadS
Nov 27, 2012
70
west bend wisconsin
I saw the sequence on youtube this morning for setting the high idle. You hold the gas pedal to the floor and pump the brake three times. Same way to turn it off. So it was 6 degrees out and I tried it and it worked...after about 30 seconds she reved up to 1200 rpms. As soon as you touch the brake the high idle kicks off. Truck warmed up twice as fast. Plus haveing it pluged in helps a great deal.
derek06
Feb 6, 2012
452
35
massachusetts
No trans yet :( its getting pushed back a little bit due to me wanting to pull at the keystone nationals in march against some prostock diesels :)
