HELP: Eliminating hard fuel lines
Hot COCOAL
May the farce be with you
Jun 9, 2012
4,433
I put this in hard parts under LBZ, cuz thats what I'm working on...
If there's a better section please move the thread!
So, I'm looking to change out the hard fuel lines and just go straight from my AD2 to the CP3 and I'd like to know if anyone's used one of the FASS kits to make this happen?
The kits come with various fittings and quite a bit of hose (length) and I'm wondering if in the kit there's fittings for:
1) to screw into the CP3 inlet that would eliminate the barbed fitting and make it a threaded to -AN
2) [id like to also] to screw into the sump to remove the screw/barbed fitting and go to a screw/-AN fitting
Here's a link to the kit(s)
http://www.fassride.com/shop/accessories/class-eight-fuel-line-kits.php
I've also been looking at Parker nitrile rubber hose to just make my own kit.
But I don't know what size and thread pitch the cp3 inlet is, size and thread pitch my sump outlet is and if it is possible to to the same (switch out to a thread in -AN out) swap at the fuel cooler so I can run my returns from an under hood fuel block the cooler.
Thanks for any insight y'all can provide-
Jason
07metallicgreen
Nov 24, 2011
207
Smicksburg, PA
just get a 1/2" cp3 fitting and get a barbed splice. cut the factory quick connect off and splice it straight to the cp3. you would have to delete your factory fuel filter
Hot COCOAL
Jun 9, 2012
4,433
Fuel filter is deleted, I have the 1/2" CP3 fitting already and I realize the "easy" thing to do would be to remove the quick disconnect and shove a hose over the hard line, but I don't want to hack the factory hard line, I'd rather replace it with something that would potentially have less bends that held a more consistent I.D that was also shorter in length and a more direct passageway from the AD2 to the CP3
07metallicgreen
Nov 24, 2011
207
Smicksburg, PA
I don't know if I made it clear. instead of using the hard line, cut the quick connect off the air dog line and splice it. don't use the hard line at all. just come straight up from lift pump, under the glow plug module to the cp3 with rubber hose. if that makes sense?? instead of going across the motor than back over just make a straight shot up to the cp3
ScreaminDuramax
Sep 19, 2013
345
Torrance
Hes got the right idea, The supply and return are right next to eachother. Sounds like the easiest way to go about it, oreilly and napa have the barbed connectors in stock.
Hot COCOAL
Jun 9, 2012
4,433
A-ha, ok yeah that's more clear.
Yes this is what I'd like to do, with the exception of using press fit fittings instead of barbed, and I'm hoping to get a -8an or -10an fitting that will thread into the CP3 and make the connection at the CP3 a threaded connection instead of a barbed connection.
Then I'd also like to use a fuel distribution block that will allow me to do two things.
1) I'd like to run the ALL the return lines into it and exit in one -6 or -8 line off a threaded connection
And
2) I'd like the distribution block to have an extra input that I can run dual pumps into later...but it's recently come to my attention that I can drill and tap a new port at a later date if I need to
That's my goal anyways.
Theres reasons for me screwing around with it too..
1) I eliminated the factory fuel pressure port a while back and have had a minor leak since from the return line at the splice point
2) I also deleted the factory fuel filter and have never liked or been satisfied with just looping a hose from the hard line that went to the filter, to the CP3.
3) I just wanna clean up the under hood "look" a bit, I'm moving the GPM over to the firewall and the quick disconnect fittings and the crossover feed hard line and return lines look like shit to me, so I wanna just get rid of them...
BLACKMAX1
WAY2EVL
Jul 10, 2013
555
VA beach
The ATS cp3 kits come with NPT to AN fittings for the factory cp3 to theirs and the fuel rail. They use high pressure steel braided Teflon line, it's appears to be aviation grade 12,000psi burst or so. I've ran them higher at work and they held fine "the aeroquip lines that is". I've been meaning to call ATS but I'm sure I could find the fitting size on my own, I think their #6 and #8. So I eventually want to run braided lines from my lift pump to my cp3s and eliminate all of the hard lines on the motor and filter head. The new lines will Y coming into the engine bay pressure will have a T before the Y or only a cross to incorporate my fuel press sensor that is currently in the bleeder fitting in the factory filter head. I'm also going to make a braided line for my PPE high pressure line. I have not looked at the lift pump to see how to connect it there, or how the return line will route.
moparkxracer
2,309
33
Out and about
Fuel lines
I am running -12 into each lift pump from 2 separate sumps,I found the fittings that screw into the airdog and make lines -12. From the outlet of the lift pumps I'm running -10 line with a one way valve on each line to a distribution block I put my lift pressure sensor in that block. From that block to the cp3's I'm running the hose -10 hose, and reducing it to -6 to plumb into the cp3's. I found the an adaptors from summitracing. The second pick is my fuel return block. I removed all the stock steal blocks from the top of the engine. I should have it mounted this weekend... I hope this helped out some.
picture.php
picture.php
BLACKMAX1
WAY2EVL
Jul 10, 2013
555
VA beach
Are the fuel blocks in both pictures of the same block? What are the barbed fittings for? Great set up defiantly helps put together some ideas.
moparkxracer
2,309
33
Out and about
Blocks
The feed one has 5 holes ( 2 in 2 out and one for lift pressure gauge), the return one had 4. I drilled and tapped for the barbed fittings and for temp sensor, that fitting was a -10 o ring with and Allen head. The Allen part was tapered and fits the o ring nicely. The two small barb fittings are for the injector returns ( one per side of motor) and the bigger one is for the fuel rail return.
onebaddmaxxx
1,212
Cecil County Md
in the puller, it has dual air dogs, separate 1/2" line up to the engine. in the last 12" from where each line connects to the cp3, there is an H in-between the two supply lines to equal them out. HSP said that having the balance hose in-between just ensures one pump doesn't starve and they each have the same flow not to fluctuate pressure between them. No issues here
moparkxracer
2,309
33
Out and about
Yes, I agree
I just put mine under the truck, and put a one way valve one each. That way if one pump does take a crap on me the other just does not push fuel back through it back to the tank.
DPC
323
Adams, TN
Advantage?
BLUF: Does any of this have a HP advantage or it this just for cosmetic reasons?
The factory feed line is a 1/2 inch, are folks running out of fuel because of the fuel line size? I did some research on the fittings and lines and you can spend a ton of money on this if you choose. Thanks.
moparkxracer
2,309
33
Out and about
Bottom line up front: I didn't like how the factory stuff looked or how it tied in, so I changed it. Depending on what's done to overall setup I'm sure the factory 1/2 inch line will become a restrictor at some point. Maybe some of the high hp guys can chime in. I'm running 2 5/8 feed lines to under the hood.
moparkxracer
2,309
33
Out and about
Lines
Yes, abt 3 ft before the cp3's I stepped them down due to hose being so huge it won't fit in the area of the valley pump. I am asking for more air and fuel them most setups. Don't go off what I have done.
Hot Cocoal, I hope the text messages helped you out in getting the part numbers you where looking for, as for the other an fittings you'll have to figure that out when you start putting stuff together. You could and should be able to get away with way mess then what I have done. I have a large oil cooler, oil bypass valve and large fuel cooler I have to work around. Let me know if there is anything else I can help with.
One to each CP3?
NC-smokinlmm
<<<Future tuna killer
May 29, 2011
5,032
243
At Da Beach
I just ran a new piece of fuel line from my AD to the cp3. I left the factory stuff in place and used it as a mounting point for the new line, I just zipped tied it every 12" or so...
DMAXchris
It’s only temporary!
Apr 28, 2009
2,274
Natrona Heights PA
Guys have hit 1000hp with all the factory lines in place. I don't think it does a damn thing for power, just cleans stuff up on top of the motor.
