No, you can get a single tune changed but it would need to be loaded into an auto-cal to load into the ecm, or ship the ecm to your tuner, either way you can have a single tune changed out of your tune files.
Not 100% on this but the way I understand it is you have to do a full flash the first time to get the ecm set up for dsp5 tuning and then after that you can do a Cal flash if you change something else.
For any ECM you have to do a full flash to make it a DSP2/5. For 04.5+ you can do a cal flash to make DSP5 changes to the DSP files, but LB7's require a full flash every time to make a DSP change to a DSP5 tune. DSP2 though can have a cal flash o nany of them to make changes to the DSP file.
