Fuel system
witmerlmm
Apr 6, 2017
21
Okay so my truck was running perfectly fine before this happened. I unhooked and unmounted my whole 150 fuel system just to clean it all up and when I hooked it all back up I have to prime my truck to start it and when it does, it only runs for about 5 seconds then dies. I don’t know what the problem could be since my truck didn’t do this before. Any help would be great.
IOWA LLY
Yes, its really me
Feb 23, 2007
2,275
You have either still not primed the system up completely. Or you hooked the hoses up wrong.
The line going to the engine should be from the round aluminum block sticking up out of the top. The return line to filler neck right below that. The fuel tank to pump inlet is the one by itself on the other side.
I think**** I’m on vacation and going from memory here.
witmerlmm
Apr 6, 2017
21
I have the hoses hooked up the right way. Must not have it primed all the way. Not sure what else I’d have to do to get it right.
Ron Nielson
697
116
Berryton, KS
You just need to prime your system. Push the button on the fuel filter head may be 10 times, them open the bleeder screw to let out the air. pump up again until hard. Start truck.
320
meh turn fass on open bleeder, bleed, close bleeder start truck
definetly sounds like system isn't fully purged...
sounds like you double checked hose routeing.
