I am at wits end with my LMM. I have done all fluids, levels are perfect. Did both new shocks, new hubs on both sides under 1000 miles ago. I have a howling around 50/60 MPH. I tried to check the CVs, no play noted, have also checked both driveshafts and they seem tight. Is the best way to check a CV to pull the shaft and have it out of truck? It is a howling and does go away at a bit higher speed.
Looking for any tips. 08 LMM stock keys no lift etc. Front set a bit lower than rear.
Thanks.
Thanks.
