Last week I pulled my trans (07 classic LBZ with Allison 1000 6 speed) to change out the torque converter seal... a LONG hard job for a $20 part. It went fairly smooth,torque converter had no groove to speak of, new seal went in great!
So now it is back together! but I have a NEW leak on drivers side front on trans pouring out???? I can't see the fluid coming out at idle, got my dad to give it some RPM's while I was under it to "try" and see where it was coming from with no luck. (does the trans build line pressure in park with RPM's??) The leak is like behind the oil filter up that high. It's not coming from the transfer case overflow, where is it coming from?
Weep hole out the front of the trans is dry, just drivers side.
PLEASE HELP ME! I am getting really down :spit:
