Hopefully gonna start pulling workstock this year. Might get to test it out for the first time this weekend. I've got caltracs, 1.5 inch travel bump stops, front end strong enough and a few other little things to be ready so far. As of right now I don't have a weight bracket, so I may try to hook without one till I get one built. Is that something to be worried about, I realize that its easier to break stuff with out hanging weights but once or twice should be okay, right?
Gonna most likely use cooper sts's 305/70 on a 16x10 wheel. Tires have half tread on 2, and 3/4 on the other. Thinking I should use the 3/4 thread pair on the back If I don't have weight to hang? Or should I do it the other way around? I'm unsure of the the tire psi also.
As of now I don't have a lift pump hooked up so that and the lack of weight ballast should be my only real disadvantages. I guess I can throw weight in the rear of the cab, or the bed also... Any tips for a first timer like myself?? Also had the idea that I should just floor it instead of building boost off the line to keep from spinning too much without hung weights, yay or nay?
