Somebody PM'd me as to which size housing I run on Casper. It's the 1.15 A/R housing. This is the "right size" for our trucks for 2000-4000 rpm operation.
What is a 1.28 good for? What is the rpm range on it?
I got a 1.78 A/R on one charger I'd like to test. But it's VNT. I can turn it down to perhaps .5 if I close the vanes.
A 1.1 is about right for our trucks. You should have no problems getting a 1.1 up on the charger at normal altitudes.
Keep in mind the compressor actually controls how much boost you can make at high RPM, not the turbine housing.
The turbine is just the drive motor for the compressor. If the compressor is too small, all the shaft RPM in the world won't change that.
How many RPM do you want peak power to be at?
I'm swapping the 1.15 to a 1.28? on Casper to do some more testing of high RPM operation.
We know that a 1.15 won't spool without nitrous when over 8000' DA.
How do you like the 1.28 so far? I havent been able to make it to the track yet but I did tow a good 12k lbs with it the other day. So far I dont think it is too bad but I haven't ran a 1.15 before.
