Erratic oil pressure
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
33
Lexington, Ky
What can cause oil pressure to fluctuate from 75-30 back and fourth in a split second? Could enough blowby be sloshing oil so much that it pulls air bubbles into the pick up? The relief valve seems to work properly and the pickup is sealed good. The bypass in the cooler just bypass' filter correct? That would not cause such a problem
Huffy67
Dec 26, 2014
270
Arkansas
Not usually I don't think and if it's only doing that at the end of your pulls it may have nothing to do with the sending unit. But it is a cheap easy thing to try and see if it fixes it.
Henry95
283
My lly was just doing that and I replaced the sending unit and it's good now.
Henry95
283
Read high and low in a split second?
Yes from go from normal to nothing. Would not stop bouncing around then stayed on zero for a while. Fixed it a couple days ago and it's good now.
ripmf666
15,123
14
47
Wentzville Mo
I will not use or sell mellings pumps. Had issues with one before holding very high pressure that's not needed. And did the same thing your seeing now. Was spinning the gear on the shaft.
mike diesel
I'm alright.
Sep 6, 2012
4,005
SLC, Utah
When was this? From what I understand, they swapped to the left hand threaded shaft because of issues like that. I have zero issues with my left hand melling pump. I see normal oil pressure as well.
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
33
Lexington, Ky
Yeah I mean I've never had issues with my right handed pump even.
ripmf666
15,123
14
47
Wentzville Mo
Has been a few years now. The pump was putting out 90psi in the warm weather and when temps dropped late at night early morning caused 100 psi +
After a issue I rather stick with a part I know works. Even with left hand thread have pump shaft keyed and gear don't trust a part with a small surface. To hold with the nut only and grit surface to supply blood for you built motor kinda like having a weak heart waiting for it to shut down.
Pic to show key way was a back up lb7 pump.
ty_LBZ
Camaro killa
Dec 6, 2014
297
Farmington, NM
Faulty stepper motor in the gauge?
56taskforce
1,074
51
Ben check the engine harness plugs top of the driver's side valve cover. I was chasing the same problem simply pushing the plugs together with a large pair of channel locks cured the problem. Note: the plugs appeared to be fine before I used the pliers on them it was a last ditch effort but it worked...
