Has anyone run into this before?
I have a 2006 Chevy 2500 with an LBZ with Diablosport predator set at 85 and Allison. The engine or something in the engine comaprtment is making a noise like a few thousand crickets. the noise only happens at 1300 rpm. The noise disappears at 1250 and 1350. Usually running anywhere from 30 - 40 mph. I have had it into technicians and they replaced a cooler tube on the turbo and turned me loose. Only to have it reappear 3 blocks later. I have had this sound for about 8 months. I have not experienced any performance loss or malfunciton of engine or turbo. I have tried putting the tune back to stock but still no change. Noise only happens at this 1300 rpm under basically an idle load. it is quit noticable if you are drivin past a building with your window down. Quite annoying noise.
I see no oil leaks and cannot recreate the sound at neutral
I checked clamps on the intake (stock) as well as intercooler.
I am at a loss for ideas on what to look for.
