Tried to start the truck. the engine was a junkyard engine pulled from a running wrecked vehicle. pulled engine apart and injectors and cp3 looked to be new.
I modified the wire harness and i did accidentally cut one wire but i fixed that.
The problem is i will crank it and it will only build up 200psi in the rails. cranking rpm is 180ish.
No codes, i have swapped the FCA, Rail pressure sensor and FICM. nothing has changed after changing each of them one at a time.
Still cranks and only makes 200psi in the rails. Tried unplugging the FCA and no change in rail pressure while cranking.
Checked the large bale connectors and i have 12v going to the pink wires on both sides of the connectors. wiggled them and no change.
its late maybe i missed something. all the grounds are connected.
Besides inspecting the fprv, the next step would be to check return rates i guess. and maybe plugging the return line from the cp3 and cranking.
besides that id there anything im missing?
