Cp3 removal
1,756
yep, four bolts from the front, fuel lines and electrical connector. then pull straight back and its free
Bdsankey
3,914
1,074
Neenah, Wisconsin
If you’re sure you have the correct 4 bolts removed get a pry bar
^This. I don't know how many times I've had customers (hell, I still do it) not remove the correct 4 bolts and sit there saying "why the hell won't this move?"
Once you've got all 4 bolts out (the correct ones) I take a small pry bar and lightly push on the nut from inside the oil fill hole and they usually pop right out without much fuss.
Reactions: Dozerboy
Dozerboy
4,815
395
TX of course
That's good advice. I know I had trouble the 1st time I pulled mine out, but it was easy after that.
