Compression levels - LBZ
YoungGunDiesel
Jul 19, 2017
45
Did a compression check on my 2006 LBZ and got the following,
Cylinder #1: 350
Cylinder #2: 320
Cylinder #3: 320
Cylinder #4: 240
Cylinder #5: 330
Cylinder #6: 350
Cylinder #7: 310
Cylinder #8: 300
Should I be concerned for #4?
Sent from my VS995 using Tapatalk
YoungGunDiesel
Jul 19, 2017
45
Yes. Id also be wary of 7 and 8 myself.
Do you think it can still be ran before any issues arise? There was no blow by. But I needed to change injectors so I decided a compression check would be a good start before I order new injectors.
02greysixer
1,829
North Central FL
You sure you got accurate readings? Doesn't take much of a leak to give a lower reading? With a 100 psi difference I would think you'd have a noticeable miss at idle. And a 240 psi you'd probably have smoke when cold too.
Sent from my SM-G930P using Tapatalk
YoungGunDiesel
Jul 19, 2017
45
Here's the kicker. It does sound like there's a miss and it smokes like a train from the bad injectors. So I'm not sure if its a combo of two or what.
YoungGunDiesel
Jul 19, 2017
45
P.s these readings where received from a 29$ harbor freight compression tester.
YoungGunDiesel
Jul 19, 2017
45
...I...I can't tell if your being serious. Or sarcastic...although with bad injectors ill melt down pistons well before I reach 100mph
Awenta
4,090
CT
Oh no... he was serious :rofl:
5,033
Injectors are not your worry here. At 240psi, you will be smoking/hazing like a sob cold and still haze a ton when hot.
With compression like that, injector balance rates tell you nothing. The only way to know if those injectors are bad is to send them out. Your engine is too hurt
YoungGunDiesel
Jul 19, 2017
45
This is saddening news :( I wasn't expecting a motor rebuild
Just out if curiousity. If I disconnect the injector to cylinder 4. Would the smoking stop considering theres no more fuel going to it?
And also why doesn't the low compression cause blow by? I can take the oil cap off, flip it over. And it doesn't move.
Could it also be a burnt exhaust valve? I ask cause my truck mimics this guys exactly,
https://youtu.be/YK1nrGocHmg
WolfLMM
Making Chips
Nov 21, 2006
4,005
25
AL
Low compression won't cause blow by, because your rings are sealing fine, your rod is shorter is the reason.
WolfLMM
Making Chips
Nov 21, 2006
4,005
25
AL
Yes sir, that's a real possibility. However like you said, a leaky valve can cause low compression as well. You'll have to do some testing to figure out which it is.
YoungGunDiesel
Jul 19, 2017
45
I'm looking around for a leak down tester for a diesel but cant really find one. I have one for a gas motor but no adaptor for a glow plug hole. I shall keep looking into this though.
5,033
use the end of your compression testor. IIRC its just an air chuck on the gauge end where you connect it
