cam question
GSXRTURBO1
Feb 10, 2015
139
Detroit MI
On a gas engine, especially a 2 valver with overlap, a healthy cam has a unique unmistakable sound at idle speeds. It seems that gasoline 4 valvers with larger camshafts don't quite sound the same, although they too have a very unique sound at idle when enough lift/duration is being used with the cam choice, just not as radical as pushrod 2 valvers.
My question is this: do diesels react to camshafts the same way? For example, does a diesel cam with considerably more lift/duration then stock sound much different at idle? Does it sound different at all? If so, in what way?
Always learning.
Thomas
Cknight199
Aug 23, 2012
1,827
Salt Lake City, Utah
I have an aggressive wagler cam and noticed a different idle sound. I have heard of using an adjustable timing gear will really make a truck have a lope at idle.
DMAXchris
It’s only temporary!
Apr 28, 2009
2,274
Natrona Heights PA
The idle changed on my truc kwith a big Hamilton cam. Not lopey like a gasser, but its more pronounced and deep. Kinda sounds like a Cummins or piece of equiptment.
Yellow Jacket
WannaBe Sled Puller
Feb 11, 2009
917
Waterloo, IA
I run a pretty aggressive can, near .600 lift and a good amount of overlap for a diesel...it is installed with an adjustable can gear, sounds different, yes....but no lope whatsoever. There is no throttle body or intake vacuum, so the lope is not coming from a can, lol...
GSXRTURBO1
Feb 10, 2015
139
Detroit MI
good point.... how much of that unique sound from a long duration/high lift cam in a gasoline engine is attributed to intake vacuum variances? (I would think it's actually very little, and most of it comes from exhaust pulses/waves due to reversion, etc.) Is that same unique sound missing from a diesel because of no intake vacuum? Perhaps differences in i/e overlap between a gasoline 2 valve per cyl v.s. a diesel 4 valve per cyl??
Lots to think about ;) :thumb:
